I play the game modern combat 5 but in the game there is a temple call rinnoji temple is there hacker's that im playing
Games Gold, CD Keys and Games Items are available on https://www.m8x.com, Game CDKeys are cheap and safe there.
SOURCE: why doesn't my logitech work for f.p.s games
it doesnt work because your most likely programming it to the launcher, the box that pops up at the beggining when u first click ur shortcut there is no way to make it work for combat arms i've tried and have not succeded
SOURCE: ps2 games to play on ps3
you can only play ps1 and ps2 games on your ps3 if it has the same game region.hope this info helps your problem
SOURCE: Ace combat 6 wont load after start up screen
I also have this game and I had the same problem, but I fixed it very quickly. I needed two solutions, and here they are.
Solution 1: Go to XBOX Live and update your console or the game, if a patch is available. There was for me.
Solution 2: Go to your Console Settings and clear the cache. Believe it or not, this can have a significant impact on performance, even for such a powerful gaming platform.
If neither of these two solutions work, try cleaning your disc reader, or if the problem can't be solved that way, contact Microsoft and they should be able to either replace the console or fix it, provided that it's under warranty. Good luck!
-Richard B.-
XBOX360 Gamer Tag - BULLITTBUSH
SOURCE: Buffer Override Detected
http://techrepublic.com.com/5208-11184-0.html?forumID=49&threadID=172408&messageID=1754446
A buffer is a place to store data. You have a buffer overrun when to much data is sent to that place. It is used a lot by people who write virus programs and try to start a virus. It would be a good idea to check your entire drive for virus. The above link explains the same thing.
Don't forget to rate this with 4 stars before you log out.
SOURCE: My Modern Warfare 2 Game Wont Let Me Play... Please Help!!!
It could be your router or network settings for your internet. Do you use Port forwarding? The Playstation site tells you all the ports you need to use. Also try putting your playstation in a DMZ.
