TV shadow ghosting
Chances are your timing board is failing, if you replace it that should take care of your issues, only other thing you could do is remove the LVDS cable from the board, that is the larger round one and re seat it, then remove the ribbon cables that go from the TCON board to the panel and do the same with them, make sure they're clean and seated properly, to remove them there is a clip that needs to be released, don't try pulling them out or you will damage them.
