In my experience trouble are with power for LED's. Something wrong with power supply DC.
Thanks for your help. Sounds like it might beto much to mess with. I guess I will just replace it. Again, thanks.
One more thing- 'powerful' LED's have 10, 20, and so on LED's inside, when some LED's broken down, then DC power supply begins wrong job.
ALL the LED's work. I'm going to test the board and go from there. Thank you very much.
SOURCE: flash plug in installed but not working
have you seen this.http://www.adobe.com/support/flash/releasenotes/mx/rn_mx.html
SOURCE: security light
Bypass the system completely. These antitheft systems are known for failing andcosting tons of money to fix. Go to this link for info and DO IT YOURSELF solutions.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
The PASSLOCK system is not recognizing the key. You may have to go to the dealer for reprogramming. You can try this procedure to see if it will relearn.Make sure the battery has a good charge in it before trying this.
1. Turn key to the on position ( don't try to start )
2. Leave key in on position for 15 minutes
3. Turn key off and wait 10 seconds
4. Repeat this procedure 1 more time and try to start the vehicle
New contacts occur everyday and with a little initiative, the person may be able to near a sale or be referred to someone who may need it. AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
