SOURCE: I get an error message c000 when i turn on my
Feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective. The purge unit pump or hose is clogged...recommend having serviced by tech.
SOURCE: i have a canon mx860 and im getting a error code
the print head is blocked?
Cancel printing and turn the machine off. Then remove the jammed paper or object that blocks printhead.
NOTE
If you have not removed the protection, follow the procedures below.
1.Open the output paper tray.
2.Lift Scanning Unit (cover) until it stops.
The support of the scan unit is automatically locked.
3.Remove the orange protective tape (A) and the protective packaging (B).
4.Ensuite,
slightly lift the scanner unit (cover), fold the support of the scanner
unit and then gently close the Scanning Unit (Cover).
CAUTION
* Do not touch the components inside the machine. The machine may not print correctly.
Put the machine on.
SOURCE: HI my canon pixma MX870
Try removing the printhead and then turn off the printer. Turn back on and wait for the prompt to install the printhead and cartridges.
I had the same error code and this worked for me.
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay klhnc
