This error indicates that an internal error has occurred which may be resolved by resetting the printer. Please follow these steps for isolating and resetting the printer:
1. Open the printer's front cover, and then open and close the print head lock lever (do not remove the print head).
2. Make sure all ink tanks are seated properly.
3. Make sure all packing materials have been removed.
4. Make sure no paper is jammed in the printer.
5. Disconnect the printer cable from the printer.
6. Close the front cover and turn the printer off.
7. Unplug the printer from the power source, and then plug it back in after five minutes.
8. Power on the printer.
If the error returns, the printer will require service options.
Chose my answer as "Helpful" if you fix the problem. Thanks!
SOURCE: i have a canon mx860 and im getting a error code
the print head is blocked?
Cancel printing and turn the machine off. Then remove the jammed paper or object that blocks printhead.
NOTE
If you have not removed the protection, follow the procedures below.
1.Open the output paper tray.
2.Lift Scanning Unit (cover) until it stops.
The support of the scan unit is automatically locked.
3.Remove the orange protective tape (A) and the protective packaging (B).
4.Ensuite,
slightly lift the scanner unit (cover), fold the support of the scanner
unit and then gently close the Scanning Unit (Cover).
CAUTION
* Do not touch the components inside the machine. The machine may not print correctly.
Put the machine on.
SOURCE: canon mx860 - had an error code C000 and now a day
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or
foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
