SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
SOURCE: washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
SOURCE: Hi, I have an Electrolux EWF1087 which is flashing
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
SOURCE: Electrolux EWF1087. door locked shut. when i reset
sounds like door lock is faulty e42 is saying door is still open. could be wiring to door lock also.
