I don't totally understand what you're asking. Someone in our shop worked on one of these a few mons ago that had an open primary in the main transformer. The input voltage was 120 and the output was 35 vac center tapped. Not sure if this was what you was asking.
Is there a fuse on a Victrola record player?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I get my Victrola record player to work?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Why is my Victrola blinking blue?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Why did my record player stop working?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback
What is required though is for the same capability to be supported by your PC.
If its bluetooth connected, the PC must also be bluetooth capable, if the PC is not you can always get a bluetooth adapter to make you PC bluetooth capable.
If its infrared, then you need to install the adapter that came with it, usually they come with a usb adater.
Hi James, I am not an expert on iPhones or Bluetooth, but suggest you go into the main set up menus on both devices and then disconnect both and then search and re match and accept them. It should work correctly then. Regards John
Buy a phone with Bluetooth capability or connectivity. If your phone has no Bluetooth application from the factory then it can not be added. If your phone has Bluetooth you can always Enable it by checking the Connectivity Settings and Activating it so you can be able to use it to connect with other Bluetooth-ed accessories and other technologies.
Hi, If you have lost the pairing on your phone with the headset follow these simple steps below: • Setting the headset into pairing mode 1) Ensure the headset is fully charged 2) The headset must be switch off 3) Press and hold the on button for +- 8 seconds until the light flashes red-blue 4) The headset is now in pairing mode • Searching for the headset on the phone 1) Go to “settings” or “connections” 2) Select Bluetooth, then options 3) Select Devices and click add 4) The phone should search for any available Bluetooth devices and display what was found 5) Select the Motorola device and click add 6) You will be required to enter in a pass code which is standard ‘0000’. 7) If successful then the headset will start flashing BLUE every few seconds. 8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device. • The headset is now paired with the phone
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select BT350 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
