The 5d code is actually an Sd code and it means suds have been detected in the washer. This can indicate to much soap or the wrong kind of soap was used in the washer. Be sure HE detergent is being used. If can also indicate the drain pump is restricted or the drain hose is kinked.
My kenmore he2 plus washer gave me a 5d code and door locked ...
https://www.youtube.com/watch?v=-v66USc48o0
SOURCE: Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
