I've tried charging my Eleaf iStick trim but the battery level lights blink 3 times but doesn't fire. Can it be fixed if I changed the atomizer?
SOURCE: Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
SOURCE: Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
SOURCE: My PSP's charging light is blinking but it doesn't charge
Have you tried a new battery?
They can only take so many recharge cycles before they die like my Ryobi cordless drill stuff
SOURCE: My battery is less than
Usually batteries are not covered under a warranty, IF they worked in the beginning. It has a lot to do how it was stored in the winter, it could have been your problem and not the batteries.
