Techumpseh 5hp HSSK50 snowblower (MTD) dies under load. good compression, new carb, good fuel flow.
governer or valve lash diagnosis?? adjustment?
dies in 4" of snow.
non ethanol fresh gas.
Re: Techumpseh 5hp HSSK50 snowblower (MTD) dies under...
Even though it's new the fuel jet could be dirty. If you don't have an air compressor to blow it out get yourself a piece of fine wire and put through it. I have done this before and this was all my problem was.
This can be very frustrating and tough on the back and arm.
Always confirm the the fuel tank valve is open and the stop/run switch is in run position
It takes three things to run:
Compression. This is the resistance that you feel as you crank the engine. Some engines have compression release to assist getting the rotation started. You should be able to feel the compression stroke as you rotate, Remove the plug and you can easily tell the deference. If it had, last time used, been running and starting with no problem I would assume that the compression is OK. Gauges are available to check. at lease 120 PSI
Spark. It is near impossible to lose the spark timing on these. It can only be magnitude and presence. If in doubt about the condition of spark plug replace. I usually lay the plug on top of the head with wire attached and observe for the spark. No spark no start.
Confirm that the throttle is in the wide open position. It is possible during the repair the spring or rod has closed the throttle air valve. Air/fuel mixture is always hard to trouble shoot. I use open choke and starter fluid to conform that compression and spark are working. After that I will choke on a cold motor and pull listening for the first fire. At the first fire I would usually half choke and pull to first run. Full choke for many pulls will only flood engine!! If no joy then I would allow engine to vent and go back to start fluid. If it will run on start fluid than either carburetor is messed up or quality of fuel is bad.
If after several tries and fuel is certain to be good remove plug and check for gas. It is possible that the new carb float valve or mixture adjustment screws are messed up.
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Check the valve lash-sounds like valves are tight in those cylinders. Idle air screws won't do anything if the valves are tight, the motor doesn't develop vacuum when the cylinder doesn't seal. And without vacuum, carbs don't work. If the valve lash is within specs, run a compression test, most "rockets" run a minimum PSI of 150 to be within spec. Good luck!
Try getting some carb. Cleaner and clean the carb.or as I have said before put a little seafoam n your gas and let the motor run for a while it may help
My 5hp B-S is doing the same thing and found a post that seems to be the best answer. Replace the float. It runs out of gas if the float is not working properly. Another cause may be the diaphram, maybe. Mine is 12 yrs old so I plan on getting the whole carb rebuild kit while I have it apart Good Luck
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
snowblower no fuel . pull float bowl from the bottom of carb the bolt you removed from the bottom to take off the float bowl there will be a small hole in it take a needle make sure to clean it out . then clean out where it threads into .
