Internal amp taking a dump. I would disconnect unit from power.
Bad Pico fuse? Due to bad rca ground. Ground outside of rca outputs to chassis of head unit
First of all shut it off. The reason it is losing sound because it is cooking itself to *****. Depends when you purchased it as to whether or not it is under warranty.
Not sure what kind of car you have but,,, just for the heck of it, when you turn on your lights , try turning your interior dimmer all the way up. If the radio works again, then you have it powered from the wrong wire in the dash. It needs to go to a constant hot (12V) and Accy/ignition (12V) and not to a lighting wire which would power the back lighting of a factory radio.
