The piece is mean to come out for cleaning purposes
SOURCE: Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
SOURCE: I am looking for a free manual for the Eumig Mark 8 projector
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
SOURCE: I need a manual for a White 2200 multi- tasker sewing machine.
You need to take this to a repair person.
I do have a manual but you can go to www.whitesewing.com and get one. Also the tension is a big problem if you don't use the exact bobbin. I was told that most bobbins will work in this machine but it turns out that only the one that comes with the machine really works. I would look for the parts to your machine. Sometimes they get lost in your sewing kit.
SOURCE: Keystone 8mm movie projector
Re Keystone 68 projectors:
I join the growing throngs of folks who wish to view their family archives in 8 mm before submitting the reels to the digitals for conversion. Doesn't anyone have an answer for us? I continue to search, if I find, I'll post.
Fauvette
SOURCE: what does a green blinking light mean on my eco
When the green LED starts to blink, means that there is a bulb failure in the RCI module. It typically glows greenish blue when it working. Check the connector to see if it is seated properly, and also check the power connector for problems. I had a problem with the power connect not making a good contact and it caused the power to be intermittent. I was able to clean the connector with a can of electrical contact cleaner from Radio Shack to fix this problem. If you can't get the bulb to light, you will need a new RCI module.
As for the purification plate, the one that shaped like a tongue depressor, it does not matter which way it go back in to the unit. You should be able to get parts from your dealer or you can call the company at 800 989 2299. Hope this helps.
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
This is a common problem with these projectors. Usually happens after a film breaks or a bad splice goes through it. Pull the lens straight out and then remove the lens housing that holds the lens and the focus controller. The screws for the housing are behind the glued on cover that says frame and focus. Remove the 4 screws behind it, slowly lift the cover and watch for a loose leaf spring that sits behind the cover. It will fall out if the projector is standing up, so lay it on its back and it will just sit there so you know where to put it during assembly.
