SOURCE: How to activate Voicemail on extensions
Adding Subscriber Mailboxes:
1 – Feature 983
2 – Log: = 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press MBOX
4 – Press ADD
5 – Mbox: enter mailbox number to be added
6 – Type:subscriber Press OK
7 – Ext: Dial station number (the mailbox and extension do not have to be the same, but for simplicity keep the same)
8 – Service class: Typical class is 1
9 – Name: Enter name (last name, first name) per letters on keypad. Dial as in texting for each letter. Press # to enter a comma between last name and first name.
10 – Directory?: YES or NO (for dial by name for company directory)
11 – Msg waiting: YES or NO (to enable “Message for you” display on phone press Yes)
After this set, you can pass by all the other information, since this is a basic setup for a mailbox.
Now that you created the mailbox, you still have to go into the programming to enable forwarding to voicemail.
SOURCE: I need help programming hunt
Looks like you need to set your overflows from HG1 to HG2 then to extension xxx.I'd set the delay from 12 to 15 seconds.
SOURCE: Hi i have a panasonic KX-TES824 installed with 2
A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
Carl
