Garden Logo
G
Gary grinstead Posted on Jan 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the spark plug gap for a mcculock 210 strimmer
Dan Apthorp
Level 3:
  • McCulloch Master 2,824 Answers
  • Posted on Jan 21, 2019
Dan Apthorp
McCulloch Master
Level 3:
Answers
2824
Questions
0
Helped
890025
Points
7391
.... spark plug gap is .025
5 Related Answers
Anonymous
  • 239 Answers
  • Posted on Jan 02, 2009
SOURCE: Stihl strimmer will not start
timing
Anonymous
  • 3 Answers
  • Posted on Mar 22, 2009
SOURCE: spark plug gap keeps closing on 2 stroke engine
it could be the spark plugs are to long and the piston is hitting the glug
Mike McDowell
  • 148 Answers
  • Posted on Jul 28, 2009
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Anonymous
  • 155 Answers
  • Posted on Sep 10, 2009
Normally 25 thou
Anonymous
  • 4088 Answers
  • Posted on Oct 22, 2010
SOURCE: STRIMMER TM 210 CORRECT FUEL
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines. Make sure the choke is operating properly. Be sure to use a synthetic chain saw oil in the fuel, not boat motor oil. I'm assuming that the jet screws have not been adjusted in an attempt to fix the problem. Hope this helps!
1helpful
Hi, regarding the JCB M25 strimmer, do you know the gap size for the spark plug? Thanks for previous answer, running better but not perfect.
SPARK PLUG REPLACEMENT
See Figure 9.
This engine uses a Champion RCJ-6Y or NGK BPMR7A spark plug with 0.05 in.
electrode gap. Use an exact model and replace annually.
That gap is too big.... so looked for another and found it in metric.
SPARK PLUG REPLACEMENT See Figure 12. This engine uses a Champion RCJ-6Y or equivalent spark plug with 0.63 mm electrode gap. Use an exact model and replace annually.
a
Now 0.63mm is 0.025 inches... that's more reasonable.
Mar 16, 2019 • Garden
2helpful
Ryobi rlt 30 cesa petrol strimmer will not start
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
May 14, 2014 • Garden
My stihl fs56 strimmer will not start,i have a spark & fuel new plug cleaned carb help please
if you have spark and fuel then id be looking at lack of compression.. damaged piston ring or damaged crank seal/gasket
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 • Garden
Petrol strimmer keeps needing new spark plugs
There is very little to go wrong with a newish spark plug, so it is either getting to hot ans whiskering the plug gap ( the plug will look very white around the electrode and a tiny whisker will bridge the gap ) or the porcelain insulator on the plug electrode has suffered carbon fouling due to the engine running too rich, in which case just clean the plug so as the porcelaine is white again.
Jul 08, 2012 • Garden
2helpful
2answers
#1 Spark plug not burning the fuel.
If you've checked wire, plug & cap, next is compression?
1helpful
2answers
Spark plug gap keeps closing on 2 stroke engine
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
