Exercise & Fitness Logo
Sportcraft tx 350 treadmill that will not stay on one speed.. what has gone wrong?
3 Related Answers
Anonymous
  • Posted on Mar 14, 2011
SOURCE: Have a sportcraft tx350 treadmill and it won't
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Anonymous
  • 1212 Answers
  • Posted on Jan 23, 2012
SOURCE: location of speed sensor for sportcraft tx 400 treadmill
Look for 2 small wires molded together that come from the vicinity of the front roller, or the front of the motor. Those are the wires to the sensor. They may be routed under the frame and may only visible when the bottom panel is removed.
Anonymous
  • 1212 Answers
SOURCE: location of speed sensor on sportcraft tx 400 treadmills
It is a simple magnet and Hall effect transistor if you have 2 small wires. It usually attaches to the 1/8 inch mini plug. You can test it with an analog meter, the resistance will be stable at rest, and with treadmill in motion, the resistance will change as the magnet passes the hall effect switch. moving the track at slow speed manually will be enough to see the needle move. Speed is calculated off of the rate of those pulses.
Where can I buy a key for a sportcraft TX 305 treadmill?
When I lost the key for my treadmill I used a magnet instead and it worked fine.
1helpful
How can I slow down a Sportcraft TX 320 treadmill?
Hi There, hmmm.... am I hearing that the treadmill starts too fast? At over 1mph? Most US treads will start at 1MPH and some will allow selection of .5MPH in the maintenance mode settings maybe. Otherwise, this could be attacked by a technical crew, like jatinah electronics possibly. If the treadmill would be set at one speed only that could be accomplished by reducing the drive signal at the component-level. It is certainly workable, but I would need to know what the current speed is that is too fast for her, and her ideal speed. ;o)
2answers
How can I stop my treadmill from knocking?
It depends on the frequency of the knock. Does the frequency change with motor speed?
1helpful
Caminadora sportcraft tx2.5 nada mas aparece el numero 9 y no funciona
Es para resetear una caminadora que s?lo dice 7 y no hace nada con estos pasos funciona bien otra vez.
1helpful
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Tx 2.5 is on 3
o.k if you have problem with a control board you can find from
www.treadmilldoctor.com
go and buy it.
God bless you
1helpful
Location of speed sensor for sportcraft tx 400 treadmill
1helpful
2answers
Location of speed sensor on sportcraft tx 400 treadmills
6helpful
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
Top Sportcraft Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
