SOURCE: F2 error code
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
SOURCE: kenmore elite flat top stove
Analog to digital failure. Disconect power for 1 minute. if the code comes back replace the control board.
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
