Washing Machines Logo
Stephan Leroy Posted on Jan 20, 2019
I have replaced both heat sensors and I am still getting an ERROR 4. What else can I do?
RF365PXKW shows error code F5E1
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
How to clear error code c392A on bizhub C452
Description
Heating roller temperature sensor/4 contamination (Center of the heating roller) While checking the contamination on the heating roller temperature sensor/4, detected temperature of the heating roller thermistor/1 exceeded the detected temperature of the heating roller temperature sensor/4 for over the predetermined value for the predetermined period of time.
See link for resolution:
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20654e&code=C392A
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
Should the above error re-appears, replacement of the control is required.
F2-E0 Shorted Keypad. Replace Keypad.
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 • Ovens
2answers
Error 4
Unfortunately the error message 5 indicates that the thermal block and/or thermal sensor and possibly a control board need to be tested, and likely one or more, possibly all, replaced. My recommendation is to send it to Capresso ask what it will cost first. M
Two of the baffles broke replaced them now getting a code f05 and washer beeps and wont finish wash cycle
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
Above is your service manual, look in the area of the NTC sensor,it needs to be replaced, the service manual will show you how.
You need to replace the ntc sensor, most likely.
F/05 Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
Ovens with 2 Digit Displays
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 • Ovens
6helpful
2answers
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Jan 15, 2009 • Dishwashers
10helpful
3answers
F5E1 error
>>Exception Note:<<
Top Washing Machines Experts
john h
