My best guess is it needs a new igniter harness, Though it could be the igniter module. Resistance testing of the igniter switches on the igniter harness would tell you which. Part # PE070818
May have a bad regulator
Testimonial: "Thank you for your reply. How do I test to see if it is a bad regulator? Please advise."
SOURCE: Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
SOURCE: viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
SOURCE: Viking range top 2 burners won't light
Either the igniters are at fault (which is usually the case when one or two are not working) or the entire oven ignition system needs to be replaced and can be done through
Viking themselves whether you want them to replace it or you yourself
replace it, you can get the part through them.
Benjamin
