Radio Communications Logo
minecraft gamer Posted on Jan 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you stop your headset from flashing - Radio Communications
Cherwally
Level 2:
Sergeant:
Habit-Forming:
  • Expert 156 Answers
  • Posted on Jan 20, 2019
Cherwally
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
156
Questions
Helped
62196
Points
619
I guess is a Bluetooth headset?
The blue light will flash as long as the headset is on and when pairing.
Why Won't My AfterGlow PDP Universal Headset Turn On And Stop Flashing Blue?
Have you replaced the battery? All of those symptoms are common battery issues. Even having the headset on the charger will not provide enough power if the battery is bad.
1helpful
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
2answers
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Midland btx2
The red LED on the unit will start flashing when charging begins.
Allow the headset to charge until the unit stops flashing or the blue LED turns on.
When the charge is complete (the red LED is not flashing), release the headset
from the charger
I m unable to pair my wep210 headset with my samsung omnia i900 mobile
the wep210 multifunction button needs to be pressed till blue light flashes then stops on blue light continuious this is when you ask your phone to find bluetooth devices it will pick it up
76helpful
3answers
How to pair my blue parrot b250 with my phone lost my notes on how to pair
1. Turn headset off (panel 5).
2. Hold down the headset’s MFB until the red and blue lights
flash and you hear 2 rising tones, followed by 4 more tones.
Important: Wait for all tones and for both lights to flash. This
may take up to 15 sec. Release the MFB.
3. Follow the manufacturer’s instructions for putting your
cellular phone into Bluetooth discovery mode.
4. Wait 5-15 sec. while the devices discover each other.
When the phone discovers the headset, select “Pair” and
enter a passcode of 0000 when instructed. When pairing
is complete the headset’s blue light will stop flashing and
the phone will prompt you to ‘connect’ to the headset.
Enter “Yes” on the phone to connect to the headset. When
connected, the blue light will flash indicating that the
headset is in standby mode ready to receive a call.
USER GUIDE
18helpful
5answers
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
18helpful
4answers
Hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
