Dishwashers Logo
Denise Masse Posted on Jan 20, 2019
Only can use heavy wash cycle on Jenn Aire dishwasher. Wont allow me to choose other options
5 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 09, 2007
SOURCE: dishwasher not starting cycle
aslav...Does it do anything at all and how do you know it has power? Find and turn the breaker fully off and then on to reset it.
You don't say how old the unit is. If it has a mechanical timer, is it one you can turn? If so, turn it. If it starts to do something...this gives you an idea what's happening. Try a different cycle.
The first things a timer 'authorizes' in a dishwasher are: water in and start of pump motor. If neither is happening and power is on to the connection under the unit (use a voltage tester you get from the hardware store), then replace the timer. My bet: no power.
A
Anonymous
  • Posted on Mar 16, 2008
SOURCE: Jenn-Air dishwasher jdb1100aws problem
I had the same problem , needed a seal kit w/ alignment tool.
repair part # 99003341.
Anonymous
  • 640 Answers
  • Posted on Aug 06, 2008
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Anonymous
  • 229 Answers
  • Posted on Nov 29, 2008
SOURCE: dishes still dirty after heavy wash cycle
There is a screen on the drain area of the bottom of the dishwasher that needs to be cleaned. It has a plastic mesh screen on it - you can't miss it. Second get an old toothbrush and clean out the little jets on the washing arms that spin around. You will notice these holes are clogged up with calcium deposits etc. Those things done you will have a new dishwasher again. You need to do this every 6 months or so. Also use a rinse conditioner for a while to assure the jets are clean. Good Luck
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Jun 12, 2009
SOURCE: my MDB8951 dishwasher stopped working after interrupted the cycle
Go to your electrical panel and, disconnect the power to your dishwasher for about 1/2 hours when you repower it your DW should be reset
1helpful
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
I have a Jenn aire jdb8910aww dishwasher and after every type of treatment and cleanser I still cannot get the powdery residue to go away. The only thing that works is white vinegar, but i have to use it...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Out of the blue our Jen-aire jdb1105aws doesn't want to power up. No lights, no cycles etc. Checked the plug etc and no tripped fuses. Any thoughts appreciated.
If there is power present on the controller but not outputting to the circuits then it is possible toi have the controller faulty which can be getting error messages/fault messages from the sensor or a failure of the main board..
1helpful
Only can use the heavy wash cycle
HELLO THERE
The cycle doesn't advance or you are unable to use one of the cycles such as light or the normal wash cycle, your problem normally is caused by a bad timer It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance.and if you set it to the normal cycle or light cycle and nothing happens Then you need to replace the timer. ok? hope this is veery helpful for you
Best regards Michael
2002 Jenn Aire used to wash and rinse beautiful, now doesn't rinse properly leaving detergent film on everything. Using Cascade Liquid which always worked fine before. Glasses are new so it isn't mineral...
Reduce detergent quantity. Check the rinse aid dispenser and fill if required..
Finally check your inlet water free flow to the machine. If the strainer is blocked clean the part.
I cannot choose max spin. When I hit the spin
some lower cycles wont allow high speed spin, try heavy duty.
Jenn Aire dishwasher will not empty at end of cycle
you may have something stuck in the drain pump or in the filter. you will have to do further investigating. could be a piece of broken glass or food debris not allowing the water to drain out properly. try this first and see how you make out.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
