SOURCE: user guide for hamilton beach espresso model # 40729
If you go to www.hamiltonbeach.com you will find a user guide there for this model.
SOURCE: espresso machine model 13401 user guide
www.wikio.co.uk/guide/russell-hobbs-13401-161239.html -
SOURCE: I have a Krup #865
I was able to download the operating instructions for the coffee maker. I have yet tried to make the capacino. When I do I'll let you know how I made out.. Thankyou IMDOCW
SOURCE: How to open a Hamilton Beach 40729 Espresso machine
Easy to open. It is servicable if you have enough ingenuity and can find some generic parts to fit, but certainly not designed with servicability in mind -- the thing was obviously build as a "throw away". There is plenty of space in there for generic parts, but keep safety in mind since you are dealing with electrical parts that get hot and operate under pressure!
First, you need to remove the little plug caps that cover the two screws under the door for the scoop / emergency tamper (sorry, but IMHO a more substantial tamper is a requirement!). I found that the only sane way to remove these caps is with a drill. Carefully drill into the caps. The drill bit will catch, and you can pull the plug right out.
Next you need to deal with the odd screws. They are triangle, so even if you are a serious electronics guy like myself you are probably not going to have that screw bit. No problem though, use a very small flathead screwdriver that fits as closely in one side of the triangle as possible. It will easily remove the screw (and reinsert when you are done)
Once the screws are out, gently pry the top off as indicated by john. The plastic top should have two catches in the front near the edges, and two catches on the sides about mid-way back.
SOURCE: Solis Palazzo : turn on
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
