Looks like if the harness snaps in from top...the top left would be ground... below that should be constant and right next to ground acc. FYI the harness on amazon is only $9
Go to the Jensen Website and call up their technicians they might sell you a radio harness for like $10- $20 Most retailers won sell you a harness for each radio has its own and no extra. Or you can try to find a broken similar Jensen radio and unplug its harness or go to Best Buy roadshop where they install radio's and they may have a spare jensen harness.
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
you are better off getting the wire harness for your vehicle goto circuit city they will have the wire harness you need and the smart cable for the jensen head unit so there will be no cutting just plug it in and go what is the make and model and year of your car ?
