SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
SOURCE: error message and no incline on my sole f63
1) Run the software calibration for diagnose, and troubleshooting and fix it.
2) lube the gear and shift from elevation motor
3) adjust pot from elevation motor
4) tight the wires connector
5) Test the elevation motor for defective, measure the input voltage see my personal TIPS.
God bless you
SOURCE: sole f63 key
please download the owner manual from www.fitness.manualsonline.com and see the section how to assembly and reverse and proceed according.
God bless you
