Codes unique to make and model. Look in Owners Manual to see if codes are listed and see things to check. Go online and search "make" Washer "model" Code 58. Also, what the problem is with operation. See "Troubleshooting" in Manual for problem solution.
HP Support Communityhttps://h30434.www3.hp.com > td-p
Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ...
From User Guide:
Interference from a similar unit operating nearby:
a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory
b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Easiest way is hooking up temporarily another speaker, one that you know that works, to isolate the problem, either on the cable, or the speaker itself. Just connect it in parallel to the door´s speaker terminal, it wont hurt the head unit. If you still get no sound, make sure the head unit is not damaged for the left side. if there is sound at the headunit, you will have to rewire.
SU4-D is your model number. This is a very old cook top. Older units have a catalog number and not a model number. SU4-D stands for surface unit 4 burners.
To call spain you need to dial exit country code+34+city code+the number.Now i dont know what city your trying to call but ill give you some,Barcelona-3,Bilbao-4,Candiz-56,canar-58,Ceuta-56,Gianada-58,Leon-87,If you post exactly what city your calling ill give you the city code
Call manufacturer of radio if it is an aftermarket unit with the numbers you provided. They can give you the code for it. If it is the stereo that came with the vehicle get the VIN# and call the maker of your car. They have the code on file.
