SOURCE: Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
SOURCE: Installing belt on sander
Remove table assembly.
Remove pointer and then slide cover up and out from dust reflector.
Release belt tension by pushing tension lever toward idler drums.
Note: there may be an arrow on the inside of the belt.
The arrow should point in the direction of belt travel to ensure that the splice in the belt will not come apart.
Slide new belt over the drive and idler drums; center belt on drums.
Push tension lever towards drive drum to tension belt.
Hope this helps.
SOURCE: my 10mm air belt sander front end bearing is
no doubt you will take the old bearing off, and take it in to a bearing seller and they will no doubt, they will be able to supply an exact replacement.
Copy paste that address, below to the address bar, and that will show you all the bearing sellers in Sydney.
http://maps.google.co.nz/maps?sourceid=chrome&um=1&ie=UTF-8&q=bearing+sales+sydney&fb=1&gl=nz&hq=bearing+sales&hnear=sydney&view=text&ei=cSynS-fuKoOqtgPV8I29BA&sa=X&oi=local_group&ct=more-results&resnum=1&ved=0CCQQtQMwAA
