SOURCE: Jura impressa x90 keeps beeping
may need descaling, if this is the case you always need to descale first
SOURCE: Describe your Jura Capresso Impressa Z5 Espresso
will start by itself after it was shutoff for after
7-12 hours suddenly ? Why
SOURCE: Hi,
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
SOURCE: Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
SOURCE: jura f7 clean message wont disappear after running
First you need to be sure that the cleaning program is completed, if you cancel the program before it`s completed the machine will keep asking for cleaning. If you have tried to run the program several times and the alarm still lights up, then there`s a software problem. The only way to reset this is then to change the Main electronic board, that is very expencive and you should really concider to live with the alarm
