SOURCE: 4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
SOURCE: dead htc diamond
I have had this happen to me a couple of times. Have you tried a soft reset? Pull the stylis out, next to the usb connection you will find the reset slot.
You could try pressing and holding the power button a couple of times.
Make sure you battery is charged or good
SOURCE: 4E code keeps apearing
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
โข Make sure the source water faucet is turned on.
โข Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
