SOURCE: scope won't sight in
Yes, rim fire scopes can't be used on a stronger firearm as the recoil will alter the internal mechanism. I fought with scopes of all types for years until I bought a used Leopold, never finding a better one! Hope you can find one of those.
SOURCE: bushnell holo sight
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
SOURCE: how do I adjust the
in a word you cant,,,,,its a 4x28mm so its a fixed scope at 4x's mag with a 28mm lens
SOURCE: I have an old Tasco
the tasco rama Used the NR 52 battery that is no longer made for health reasons .it had mercury inside it.you can try a CR 1/3 N Bbattery.
SOURCE: help to reasemble a electro dot sight a parts list might help ?
I know about classic scopes... (not so much)
DOT, red or electro ...??
Besides under the windage and elevation adjustment (zero) screws... I can't think of a third "spring"...
Knob springs... perhaps ((but these "SPRINGS" are usually tempered steel compression washers)).
Try putting your model number with a search for "EXPLODED+VIEW"
Hope this helps.
Go to Bing homepage
