Stand by problem
SOURCE: i need the base stand for my tv cus been wall
Not all Philips tv's will use the same stand. First, look on the back of the set for the model number. You can purchase most television parts, including stands and base assembly at http://www.partstore.com/
SOURCE: TV Circuit board diagram
dead set line out put transsister short replace new one one secound ossalation then short plese solve the problem
SOURCE: Videocon TV model No. CTVVBN14MGF-CNA goes in
There should be some loose solder terminals at its main power regulator section. Resolder all the suspected solder terminals there, by applying a little more solder. Check the solder terminals at the horizontal output stage too. The fault is with loose solder terminals itself.
SOURCE: Any one have the service manual of SANSUI MODEL CTV SFS21 ultra slim flat tv?help me
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
