SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
SOURCE: Instruction manual for Whirlpool Heavy Duty Series 8 Machine
I have the manual if you need help, but the mechine is simple to use, just put the fabric conditioner in the top of the thing in the middle (inside the machine) the bleach dispenser is is just for bleach. You just get a cup of washing poweder and throw it in!
SOURCE: Need an instruction manual for a Century 10 amp battery charger
Are you having this problem on a particular battery? Try using it on your car's battery with the headlights on. The headlights should brighten and the unit show 5 -10 amps charging.
A car battery can develop a problem where the battery post gets disconnected from the inside. This is common on batteries in storage or left on charge a long time or used in a car with a defective alternator. The battery is charged but it won't start a car. headlights connected look normal until you turn the key, then the headlights will just go out. This descibes a bad battery.
Testimonial: "Thanks for the info. This is a battery for a boat which hasn't been used for two seasons. It has a indicator the should show green when charged. "
SOURCE: Can't find my instruction manual
Hi
Please copy and paste.
Regards
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
