SOURCE: I get a blue screen when i turn on my playstation 3.
I sometimes would get that on my XBOX 360 w/HDMI, I just turn the power off and then back on and it works just fine. I have mine set to 1080i.
SOURCE: my lumix camera in playback mode has on screen tv
If you can get into the menu and find "reset" you could return the camera to factory settings.
SOURCE: 32" onn tv hdmi is
Hi:
The best way to repair this problem is to replace the main signal board. The HDMI connections on the board may of come loose but replacing the board is the best solution at this point.
Without a remote control you can't select its inputs. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
SOURCE: Onn led tv stuck on photo screen is there any way i can solve this.
Replace the main board or if your good at soldering you can order the EEPROM and change that as that's what is bad in the main board but they're sort of hard to change without the correct equipment
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
