First go to the clean printheads software that installed with your printer. If it doesn't print anything then - Try a gentle clean of your ink cartridge. Dampen a soft cloth a slide it across the copper print jets. Dab any excess ink and retry, Also look very carefully inside the unit for any small piece of paper that could be interfering with the ink.
Finally do a complete uninstall of the printer and download the latest drivers and software from Canon. Also see if you firmware needs upgrading as well. Good Luck
SOURCE: blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document
How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
SOURCE: Printer is printing blank pages ink levels read full.
Make sure that what you are printing from the PC is black. This sounds so trite, but if for some reason you have set the font to white you may be able to see what you have written on the screen - but it won't print. Another possibility is that somehow the print in the document has been set to 'hidden'. That doesn't help either.
Failing that you may have to reinstall the printer. Use the printer disc to do this.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Testimonial: "thanks for the tips, it is manufacturer ink so i'll just give them a call thank you"
