SOURCE: Hood release under the dash has no tension on it. Hood will not latch closed
The latch is stuck in the open position. I always found white lithium grease worked best on those latches but any good lubricant will work. Try moving the latch manually with a screwdriver. After applying the lubricant move the latch a few times. You should see the tension return to the release, if it doesn't you have a broken release cable.
SOURCE: back hatch door closed on strap of backpack-now can't open door
Something similar happened to us. A handle strap from an empty fabric grocery bag got caught in the latch system of the rear hatchback on our toyota highlander when we inadvertently shut the door on it. We could not pull the strap free and we could not get the rear door to open or close. In the end we were able to cut the strap out (from the inside) with a pocket knife and then pull the pieces free of the latch.
SOURCE: Passenger sliding door motor won't close door all the way.
I just fixed my 2005 T&C sliding door. The wire in the plastic rolling chain is broken when resides right under the step pad. It took me 30 minutes to fix.
Go to this link.
http://wiki.answers.com/Q/How_do_you_replace_the_power_sliding_door_wiring_harness_on_a_2005_Town_and_Country_chrysler
SOURCE: my trunk will not close
There is a possibility that the remote latch cable is stuck (lubrication is gone) . With a screwdriver, NOT the fingers, try to return manually the latch, to its open position (instead of the pull open position). If you push it too far, it will go into locked position, and when you pull down the trunk lid, it wont reach its normal closed position. In that case, pull the latch back open, with the remote lever. Should you manage to close the trunk properly, spray some WD40 or some lubricant on the latch assembly.
SOURCE: 2005 GMC Savana Van
If you haven't already, you need to replace that interior door handle. 4 nuts
