SOURCE: Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand. That should take care of it.
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
SOURCE: In order to descale my
You can get a hex key set at any hardware store like homedepot, ace hardware, or sears.
http://www.sears.com/shc/s/search_10153_12605?keyword=hex+key&vName=&viewType=gal&viewItems=24&layaway=&clearance=&cName=
Good Luck please accep the answer
