SOURCE: phone wont turn on
Battery is so low it won't turn on. Leave on charger for a half hour or so and it will turn on again. Replacing the battery worked for me!
SOURCE: roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
SOURCE: The red light always flashing when the charger is empty
many chargers do that ,i think it is to let you know thy are on and need to be turned off, when not in use
SOURCE: TV went out and will not come back on. Power light
I have a akai tv, the tv went out but won't come back on. i'm still getting a red light but the tv just beep when I press the power button.
SOURCE: my charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
