The roof is almost all down to the Primer. It obviously is a factory fault as mentioned by all panel beaters. I can't have it painted as no panel beater guarantees it will not peel of again. Can anyone please help.
SOURCE: Sunbeam Stand Mixer
For whatever reason, Sunbeam must have decided to cut on costs and used a plastic gear to transfer power to the beater. I had my Sunbeam for two years and the plastic gear decided to break. End of mixer. You cannot find a replacement part anywhere. It is the last sunbeam I will buy.
SOURCE: replacement beaters
See solution for Euro-Pro EP546 replacement beaters. Call them at 800-798-7398.
SOURCE: Beaters Misaligned
If this is one of the later-model Sunbeams, the housing has an upper half and a lower half. By removing the upper half, you can see the motor and the gear train. You will have to take out one of the beater gear posts and reinsert it to align properly. I suggest you look at both gear posts and check for worn or broken teeth. In which case, you will need to replace the bad part[s].
Older model Sunbeams have a gearbox housing that mounts onto the front of the motor housing. When you remove the gearbox housing, you will see the gear posts inside. Check for worn or broken teeth and replace as necessary. To insure proper alignment when reattaching the gearbox housing, align the two gears relative to each other then push the gearbox housing back onto the motor housing. The motor spindle will slightly turn both gearposts simutaneously during this process but will keep the proper alignment. You may have to repeat this process a number of times until you get it right.
SOURCE: paint peeling on my ford f-150
I have actually fixed these trucks under warranty. The EPA is the root cause of this, and lack of testing the newer system, this problem is pretty much of the past as the newer vehicle have a better system on them to complie with EPA regs.
