Washing Machines Logo
M
Marjorie Reeves Posted on Jan 19, 2019
Broken door catch on Siemens siwamat 2105 Washing Machine
4 Related Answers
Anonymous
  • 209 Answers
  • Posted on Oct 10, 2007
SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Anonymous
  • 97 Answers
  • Posted on Jul 25, 2008
SOURCE: washing machine
is all the water out of the machine if not the door wont open.
if all the water has gone, have a look behind the small flap on the front of the machine where the filter is and there might be a small plastic loop which when pulled should release the door catch.
please note i say might as some models have this feature and some dont.
hope this helps
Anonymous
  • Posted on Jun 22, 2010
SOURCE: Siemens Siwamat 2105 washing machine leaking
Ater beeing switched on the machine does not fill with water.
Anonymous
  • Posted on Jan 09, 2013
SOURCE: I have a broken door
I feel for you because we have exactly the same problem : our door broke, the handle in fact. Everything else works wonder but the screw driver trick is bound to give in one day eventually and we'll be left with no washing machine at all. Has anyone found any infor on the door anywhere? thanks guys
Siemens Siwamat 276 washing machine not agitating
My first thought was that it was a problem with the drive belt or tensioner, but if it spins, that can't be the answer. That points to a main board or motor controller problem. In the first instance try a Power Reset. Disconnect the machine from mains power for a couple of hours, or preferably overnight. Press and hold the power button for 30 seconds and then plug it back in. If that doesn't fix it, you need a service call. It doesn't appear to be a known issue.
https://www.google.com/search?q=Siemens+Siwamat+276+front+load+washing+machine+not+agitating
My siemens siwamat xlp 1340 shows a lock key and wont operate
that means that the door catch is not operating properly you may need to replace the door lock yourself or call the washing machine engineer for a quote eric
Siemens siwamat 6140
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTMUse the link, you will need to enter the Enr number which is on the rating plate and should start W...
1helpful
2answers
I have a broken door catch for a Siemens Siwamat XB 1061. Can I get a replacement part
3helpful
Hello! Our Bosch-Siemens clothes washing machine SIWAMAT 2105 has the following problem: When it want to eliminate water, the water pomp doesn't work(we hear just some noises). We already manually...
Make sure you use high efficiency detergent.  The front load machines take a special kind of detergent to make them run smoothly.  Check your drain hose for clogs, and clean the pump again.  If none of these fix the problem, you will probably need to replace the pump.
Washing machine
hope this helps
2answers
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
