SOURCE: Got a dvr video system. connecting to network problem
I love it when people provide so much information such as the make and model of the DVR and the ISP. Makes it easy to figure out the problem, which in this case is most likely the ********* who is asking the question.
SOURCE: how do you connect an
add camera to the router that is allow it in the setup. the devices will need to be allow either by MAC address or device name.
check your user manual for correct setup procedure.
usually found on the CD that came with the router.
SOURCE: I have a H.264 DVR with system V2.00.R05. What app
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
SOURCE: I have Fuho 8ch. H.264
hello friends i have 8ch H.264 dvr i forget defalt password please help me how to get the password
