Needing to find the manufacturer information for the Hyper Tough workbench...I purchased two of them from WalMart and one of them did not include the plastic protective feet covers - 4 on the bottom and 2 on the top. The legs are metal and sharp and will scratch floors when moving the workbench and scratch arms when reaching into the top compartment. Just need info on who to contact....
Buy Cheap FIFA Coins, FIFA 19 Coins, FUT Coins and FIFA 19 ultimate team coins from https://www.fifacoinszone.com, build your team stronger
SOURCE: Leveler Leg
this company has gone out of buss,? but the speaker company.com has either bought there exsisting stock or reproduced the same speakers i have the ST3 model that is now called TST3 or TST2 higher the # the more bass it can handle. awsome speakers and you cant beat the price. sorry if my typing stinks but i hope i helped someone out there if you bought sapphire when they where a hot item here's your answer lol pete n.j.
SOURCE: VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
SOURCE: GE tFX26KR side by side leaks water onto floor
I read this on-line and it worked for me - - pour HOT bleach water down the drain once you get the ice out. I had this problem for ages and would periodically clear the ice out of the bottom of the freezer but since the bleach water went down that hole it has been clear for months. Of course I discovered my s/s had been recalled for a water problem.
The GE recalls are a joke anyway - a credit toward buying another GE product. Nope, I am replacing my GE's one at a time with a different vendor.
SOURCE: plastic coated sink protectors - rubber feet deteriorated
You can get a product called Plasti-Dip at your hardware store. It is the stuff used to plastc coat tools.
SOURCE: I have Ellis deluxe 4-in-1 convertable 8676pro and I need parts
Yup! It is 1-800-858-8323 for Ellis Customer service and parts, be sure to have your model number and serial number found on mattress support. : D
