It calls for a stereo input jack? I'm not sure but I think It is probably calling for a 1/4 unbalanced input jack , keeps your signal mono. so if you are only getting the bridge pickup. You might check your position switch. and or your lead pick up. simply take the designated wire from the lead pick up and hook it up where your bridge position pick up is connected. (disconnect that first) if you get sound, then it just may be your switch. if you get nothing? check to make sure you have your ground correct and he lead wire correct. If these are active pick ups? you''ll need a battery source. if stil get nothing. your pick up may be bad.Thats a reads digest troubleshooting explanation. check your basics first. good luck
SOURCE: Epiphone BB King Lucille guitar treble pickup in mono mode
Realize that when you plug into the one jack it disconnects the fingerboard pickup from the mix.
DO NOT USE "stereo" cables as it is intended to use TWO MONO cables, one for each side of the stereo.
IF you plug into the one jack that will connect to the bridge pickup, it will disconnect the fingerboard pickup from the mix BUT leave the fingerboard on its own jack.
That same jack will have BOTH fingerboard and bridge pickups IF the second jack (bridge) is not plugged into.
This is according to the schematic. If you find that yours works backwards, then either the schematic is wrong OR your guitar pickups may be electrically swapped.
