It will not link to the car 05 pontiac g6 gt 4 door
SOURCE: power steering cap location Pontiac G6 3.5L
it is located on the passengerside under the altenator closest to the firewall. make sure the vehicle is turned off reach in under the altenator and you should feel the cap.
SOURCE: how to fill transmission fluid in a 2006 pontiac G6 Gt
There should be a screw on the front of the trani near the coolant lines. With the engine off you unscrew the filler cap. That's on top of the trani on the driver's side. It has a little gear in fluid symbol on it. Then you take out the screw on the front and fill until fluid comes through the hole left by the screw. Remember to use Dex VI.
SOURCE: codes for a g6 radio.
radios are coded to prevent theft. if its stolen it won't work in another vehicle without the code. sometimes the owners manual is helpfull otherwise the pontiac dealer should be able to help
SOURCE: Pontiac G6 radio
probably not but the switch over is ez you probably need a harness..thats about it..
