SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
SOURCE: What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times. Guaranteed to work though is to remove top, reach down the top to the door lock. (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door. This can also be accomplished by removing lower front panel and reaching up to do the same. BTW, while in the top, make sure all the electrical connections are tight. I found some loose before, probably from the spinning action.
SOURCE: Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
SOURCE: WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
SOURCE: Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
