SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
SOURCE: Kenmore Series 80 Washer - Water will not stop running
If the wash tub overfills without stopping unless the washer is stopped, this is usually caused by a defective pressure switch or loose air hose going to the pressure switch. The pressure switch is located behind the water level knob inside the console. It is common for the rubber air dome hose to come off and cause a washer to overfill. The console can be accessed the following ways:
If you have removable end caps, the will lift of by prying up from the ear of the console and pulling from the front. Sometimes inserting a screwdriver in the slot in the top of the end cap on the back of the washer and giving the screwdriver a slight twist can help to pop the end cap loose. There will be a philips screw under each end cap that will need to be loosened.
If the end caps are not removable, you will need to slide a putty knife under the front corner of the console where it meets the top of washer on each side and push in to release the retaining clip that holds it in place.
Once you have the console loose, you can flip it up over the back panel to its resting position. Use care not to damage the small plastic hinges that hold the console to the washer.
With the console in its resting position, examine the pressure switch. It will be a round plastic switch located on the left hand side (sometimes located in the center) of the console. There will be an electrical connection and a rubber hose attached to it. More common than not, the rubber hose comes off. If this is the case, reattach the hose to the small nipple on the switch. Use care not to break the nipple. You can take a small zip tie and place it over the hose where it is attached to the nipple and secure it snugly to help keep the hose in place. Do NOT over tighten as you can damage the nipple. The zip tie creates enough resistance the keep the hose from sliding off from vibration over time.
If the pressure switch hose is still attached, double check your electrical connection. If the connector is intact, replace the switch as a last resort. If you can provide me with your model number (located under the lid along the wash tub rim) I can get a part number for you and let you know how much the switch would cost. I hope this helps you.
SOURCE: Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
SOURCE: Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Testimonial: "Thanks! Very helpful."
