Http://support.radioshack.com/support_electronics/8567.htm
I found this via Google.
SOURCE: realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
SOURCE: Realistic pro-2011 direct entry programmable scanner 20 channels
Its easily done. If you go to Googles site, and put iowa scanner codes in the search space, one of the choices there will be >>>>>
http://www.radioreference.com/forums/iowa-radio-discussion-forum/36607-ultimate-iowa-scanner-frequency-page.html
SOURCE: how do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
SOURCE: I recently came across a Realistic PRO-59 scanner
here is the link to your manual:
http://support.radioshack.com/support_electronics/doc17/17653.htm
it will show you the frequencies and settings to set them up on you scanner!
Cheers!
SOURCE: I need a manual for
Your manual is no longer available as a single document, but you can download and print individual sections of it, at no cost, here:
http://support.radioshack.com/support_electronics/28537.htm
Bill B
Listening in since the 60's
