If its a top loader and the clothes are all twisted up then i sugest replacing the capacitor
Fist make sure the adjurtatore filter is clean not full of lint its usually in middle of the tube has hole in it for suds or in front loader its at front down the bottom little square be careful when undoing this one you will need a bucket for front loader must be cleaned to remove lint thats its job put washing machine cleaner through next load without cloths than i try a different cycle near the same but not as long watch your water level as to much or little will damage closes
SOURCE: Simpson clothes Washer Model Esprit
Have you checked the water valve? here is a link showing how to replace the water valve http://www.youtube.com/user/RepairClinic?v=Fk4puRv3Vk8&feature=pyv&ad=5457342101&kw=washer%20valve&gclid=CI2f6tXrx6UCFRRKgwodM1sWZg
You should also check both side of the valve with a multimeter to assure that you have power going to the valve before you replace the valve. Please message me back if you have any further questions with the correct model and serial number and if there is anything else i can answer for you. please remember to rank how this opinion has helped in your appliance situation and have a great day
Rick
