SOURCE: Panasonic Model NN T964SF inverter
If
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
SOURCE: xantrex power inverter 1750
Sir ,
one of the ic or resistor will be damaged inside ,so kindly replace it,it will be alright.
SOURCE: BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
