SOURCE: can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
SOURCE: Troy Bilt 34073 mower - stripped spindle-shaft?
Bet on it- you might try adding an additional nut of the right size/thread or several washers to utilize the remaining healthy threads.
SOURCE: Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
SOURCE: How to tighten blade on super sawcat model 2154
Usually on portable saws there is a hole somewhere in the blade guard to put a screwdriver or something through and hold the blade still while you tighten the spindle nut etc.
Hope this helps. I only have experience of a very old B&D saw which worked in this way. I now use a more modern Bosch machine which also works the same.
SOURCE: I have a black and
If you can't find a spindle lock you can unplug the tool and find a piece of wood and put the blade against it and loosen and also tighten the blade, but most newer saws have a spindle lock located in the gear housing somewhere.
