This could be several things. There is a contactor on the outside unit that closes and turns on the compressor. If this fails then no action takes place moving the fluid. There is a start and run capacitor that aids the compressor, if this goes bad then the compressor wont start. Loss of fluid will cause this issue also.
There could be a lot of issues here .Just call a technician to look at it
SOURCE: A miswire
The blower is smoking because you have it hooked up to the same wires you've hooked the electric coil to. That coil runs on 240 volts. Those wires are typically red and black. The motor runs on 120. One of the wires should be shifted to a neutral (white wire). Assuming the motor is still alive...this will fix it.
SOURCE: Climate control air conditioner stops working due to incorrect ambient air temperature
Same car, same problem. Press MODE, FRONT and REAR buttons together to reset tempreture. You probably need to replace the sensor GM part number 15047946 it is in the front grill email me for a picture. [email protected]
SOURCE: 1999 Chev Suburban 1500 with front and rear ac -
the truck has two evaporator cores one for the front unit one for the rear unit also two expansion valves, one for the front one for the rear.
check the large a/c line going to the rear unit if the line is warm with the A/C compresser running replace the rear expansion valve.
if the line is cold then replace the rear units blend actuator motor. if the frount unit is cold then most likely the blend actuator is the problem, remove the cover from the rear unit and you will see the actuator mounted on the side of the air handler box.
the best way to indentifie the unit is to buy one so you know what your looking for.
let me know if there is any thing else you need.
SOURCE: Dometic duo therm does not cool or heat...
The vey first thing a homeowner or RV owner says when either an a/c or a frig or freezer does not get cold is, it must be low on freon. I am a certified HVAC Technician and have been working on A/C and Heating systems since 1996. In nearly 85% of my service calls, it was found that a simple "CAPACITOR" was defective, which prevented the COMPRESSOR from starting, which pumps FREON through the system. If you are not good at reading electrical diagrams and schematics; and if you are not comfortable in troubleshooting electrical components, then I would suggest you seek assistance from either an RV Dealer or a local HVAC Technician. I can usually tell if a COMPRESSOR is running by listening for the COMPRESSOR "humming"noise. If the compressor IS, in fact, running, then in most cases it is merely a matter of cleaning the EVAPORATOR and CONDENSER coils. Very seldom does freon "leak" out of a completely "SEALED" system, such as a refrigerator, freezer, window a/c unit, or RV a/c or heatpump unit. Good luck!!!
Hi James Barrett, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What make and model
Westinghouse FT5BD-030K
