Impeller not turning check capacitor or motor
SOURCE: impeller - whirlpool duet front load
youll def need to replace the drain pump assy part number 280170
SOURCE: LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
SOURCE: Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
SOURCE: Motor Hums,No Run
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluiminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
SOURCE: fan stopped running. no power to the fan (ie, no
You may find the parts that you need at the following web site...http://www.eceilingfans.com/
They have all of the capacitors there. All you need are the number of wires and the capacitor micro-farad ratings.
