SOURCE: Show Microsoft Power point on Sharp Aquos hdtv
try to right click the desktop and choose graphics options, you will have to select the correct output for your setup. i.e. laptop to monitor, etc etc see if that works,...sounds like you have a connection, you will have to play with these settings until it pops up. worked with a similar scenario, sometimes you have to do stufff twice and it works on the second time not the first, electronics are weird.
keep changing the settings in the graphics options until it comes up the way you want it.
SOURCE: TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
SOURCE: When I connect my Advent
Yes there are a couple of settings which you must change in order for your computer to register your external monitor. on the desktop right click with your mouse and go to personalize, once that opens on the lower left corner click on display, now on the top left corner about the (5) fifth option it should say change display settings, click there. If you do not see two monitors displayed, click on detect, and once you see two monitors click on apply. Now if you want to extend your desktop to the second monitor simply go to the multiple monitor drop down menu and click on extend these displays, and viola there you have it. Be aware these settings are only meant for Windows 7.
SOURCE: no sound on TV with hdmi cord
HI Mike,
Sometimes HDMI ports have their sound channel shared with the VGA/RCA port and they need to be switched around in the TV settings.
I dont know what is brand is your TV set so you will have to check yourself in the sound settings and also check for PC settings, see if you can change that around.
You can also just try another HDMI port on your TV that have the sound dedicated to it.
SOURCE: white flashing on netflix with hdmi cord
This happens with all three? You have a bad HDMI circuit in your TV. The Main pcb, will need to be replaced.
